Stumped
Old Aug 24, 2021 | 03:31 PM
Kitttransam's Avatar
Car: 87 trans am gta /89 chevy corvette
Axle/Gears: 3.27 / 3.07
Stumped
Recently I put my car back to maf system. I know my old tune wasn’t going to be right on since I made changes to my motor since then. But it was darn close. My blm’s I got in line but my wideband is showing a leaner AFR throughout in closed loop. Running around 14.7-15.8. I would think it should be swinging at a lower AFR. I have a heated O2 in fact I had an extra new one and changed it. No change. Checked for leaks also. My aem wideband is about 4 years old. I’m running superrram, 219 cam , AFR 180 heads, 1.6 rockers, Hedman headers. Accel 30 lb injectors
Old Aug 26, 2021 | 10:11 AM
Re: Stumped
Ok I’m starting to think I do have a vacuum leak. But in one of the worst spots. Lower part of the intake runners. Reason I think this, AFR changed their instructions. I don’t remember this being there about using rtv on the bottom of intake ports. Also remember one of the times I took my intake off and I was probably having a dumb moment at the time, but I do remember my intake ports being oily. My engine is definitely running lean checked a spark plug and looks fairly clean mostly. Not even tan.
antman89iroc
Mar 28, 2015 09:47 AM
MikeT 88IROC350
Sep 10, 2009 09:14 PM
torqueaddict
Oct 9, 2008 09:24 AM
92GTA
Oct 14, 2004 10:26 AM
LBSZ28BLOWN
Nov 13, 2003 10:37 AM
