EBL Main Thread Searchable PDF
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
I saw TallTim had done this back in 2018 so thought I would make one that was updated. Thanks TallTim for the idea, no need to email me that now. I was able to compress it down to 16.64mb and attach it directly here. I figured since it will eventually just get buried in the main thread that I would make a separate thread and then post in the main thread as well linking to this thread. IDK if maybe the mods want to make this post a sticky or not...kind of shocked the main EBL thread was never made a sticky.
Re: EBL Main Thread Searchable PDF
Thank you for your effort and for the PDF. I also recently needed to create a work document by merging and lightly editing several of my PDFs. I ended up using PDF Guru from a review article https://euroweeklynews.com/2024/02/2...tal-documents/ and was very pleased with its capabilities. The editor is quite versatile, especially when it comes to combining PDF files, as it significantly simplifies the entire process.
I finally got the ebl I have had on the shelf for way to many years installed and fired up. was able to down load your pdf to my phone and search for the question I had real quick.
being able to find the injector data in your pdf quickly made the first fire very easy. I do need to replace the map sensor that's reading low and get the knock sensor sorted. but it's drivable off the first map. that's pretty sporty.
thanks again.
