rpm limit
Old Jan 26, 2002 | 03:27 PM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
Transmission: 5 Speed
rpm limit
I was trying to burn this chip without asking anymore questions, but I'm stuck. I can't get the idle BLMs to come down from 160. The rest of my fuel curve is pretty close. I was thinking it needs "battery correction?", but I can't find that heading in Winbin. Could it be named something else?
More importantly, in 2nd gear I can't rev over 5000rpm. It will go over 6000 in first. What are the fuel cutoff upper and lower limits and could this be a problem if they are set at 1250 and 950?
Everything else is running pretty good.
Old Jan 27, 2002 | 06:51 PM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
I solved the rpm problem. It wasn't getting enough spark at WOT.
The high idle BLM is still there. Changing the battery correction didn't help. I'm thinking vacuum leak now.
RedLeader289
Sep 23, 2015 06:50 AM
wisemanz28
Sep 20, 2015 01:26 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
