idle running fast
Old Feb 18, 2002 | 08:42 PM
Chop_Top's Avatar
idle running fast
Hopefully everyone on this board isn't too pissed off to help out me out a bit.
I can't seem to figure what is controlling my motor to idle too fast. It wants to control the idle at about 975 to 1000 rpm... I have verified the the temp Vs. RPM and temp Vs. IAS position in the EPROM and with the ALDL. Even lowered the IAS Vs. temp to be sure. But it is controling the speed with the IAS. I can pull a vac hose and the RPM will speed up untill the IAS slows it down then when I plug the vac leak it will slow down until the IAS opens back up. (It is in closed loop)
350 Chevy crate motor 330hp vortec heads and manifold. no EGR and not changed in the EPROM
7747 ecm
Thanz for your help.
Old Feb 19, 2002 | 02:33 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
This is an easy one since I just ran into it
The reason that the idle sticks at 1000rpms is because you have the scanner plugged in. When a scanner is plugged into a 747 system the ECM enters ALDL diagnostic mode and holds the idle to 1000rpms. Shut the car off for 30 seconds and restart without the scanner plugged in. Now its back to normal.
Tim
Old Feb 19, 2002 | 07:11 PM
Chop_Top's Avatar
Thanx a million Traxion!!!!
I have not had it unplugged since I converted it to the TBI. It settled down just as soon as it warmed up.:hail:
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
Fast355
Dec 2, 2016 06:33 PM
db057
Aug 22, 2015 08:17 PM
