Is this a good idea...
Old Mar 3, 2002 | 06:54 PM
ski_dwn_it's Avatar
Engine: 2 mice and a cat
Hey guys,
I have been reading and studying this main spark table with respect to my logs. The log shows some spark retard at various areas. I pulled timing out across the boards and it took care of much of the retard. My question is...should I lower the WOT Spark Adv. down to zero while trying to get the main spark tables straightened out? I find it difficult to calculate figure out at each stop how much timing is being added at various spots. Just wanted to get a feel for what you guys thought about that approach.
I will post the results of the log for you to view at:
http://temp.corvetteforum.net/c4/ski...t/GM030204.htm
Old Mar 3, 2002 | 07:55 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Is this a good idea...
Originally posted by ski_dwn_it
Hey guys,
Your running too much timing as I see it.
34-36d?
Try 28-30
Get rid of the knock and MAYBE add a few degrees in.
Ar you using a timer or just seat of the pants?
If SOTP then you'll never get it right.
Old Mar 3, 2002 | 10:04 PM
ski_dwn_it's Avatar
Grumpy,
I am just trying to get rid of the knock right now and am VERY uneasy about how to change this graph. On tunercat I can't een see the backside of the graph. I think the approach I am going to take is to just set the values from ~3400 RPM at high load to 28* and use the G-tech and Craig's 1/4 recorder to guage the best timing. But What about the WOT timing that is added. Should I just zero that out so I don't have to worry about PE mode. I am assuming that you saying 28*-32* is for WOT, Correct? THanks and sorry for being a PITA.
Old Mar 4, 2002 | 05:39 AM
drive it's Avatar
Grumpy,
Yes, most folk zero out the wot advance-most times the most knock is where it is added.
Old Mar 4, 2002 | 11:01 AM
ski_dwn_it's Avatar
Thanks for the reply. I have them all around 28 with the WOT zeroed out. Hopefully I will be smokin em now! Thanks.
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
MantyZ28
Jan 18, 2016 08:30 AM
ezobens
Aug 19, 2015 10:29 PM
