85 TPI ecm and scanner
Old Mar 15, 2002 | 06:58 AM
86ZZ4's Avatar
Ive searched and found nothing on this,sooooo .does any one know what changes when this pig slow ecm is hooked up to a scanner and data list is selected.IAC goes to 1000 rpm,aparenly timing is also set at a fixed rate and knock sensor disables due to detenation.Anybody know what else changes???? I'm just staring messing with my own PROMs and just wonder how screwed my scanner readings are due to these things going into "limp"mode?
thanks for any replys
Old Mar 15, 2002 | 12:56 PM
HighHopes85's Avatar
It is going into ALDL mode. If your scanner has the option, try 'diagnostic' mode instead. I believe it chooses the mode based on the resistance between pins A and B of the ALDL connector.
Old Mar 16, 2002 | 07:14 AM
86ZZ4's Avatar
im using a GM tech 1 ,all i have is the one option .
stalkier
Dec 6, 2015 11:25 PM
Electro_X
Aug 19, 2015 07:59 AM
Sanjay
Aug 12, 2015 03:41 PM
mizz0313
Aug 12, 2015 06:45 AM
BOOT77
Aug 10, 2015 12:20 PM
