Knock sensor question.
Old Mar 22, 2002 | 11:01 AM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
I have converted my '86 carbed TA to TPI with a computer and harness form another '86. The .bin I am using is the ARAP, the motor is a 350. What knock sensor should I be using, from an '86 305, or from a '89 350? I ask because they are different part numbers and I think I was getting some flase knock with the one for the '86.
Are they based on motor size, harware, or software?
Old Mar 22, 2002 | 11:05 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Re: Knock sensor question.
Get one for an '89 350. From my understanding they (or the frequency tuning) are based on engine size, although GM did switch to a different type somewhere in the late '80's in the F-bodies. You'll also need to change the ESC module since that one is engine and year-specific.
Old Mar 22, 2002 | 11:08 AM
slowTA's Avatar
Car: '88 Formula
Will the ESC module from an '89 even fit an '86 harness?? I thought they looked different to me.
Old Mar 22, 2002 | 01:52 PM
I8AStang's Avatar
Yes, the esc fits, or the ones I have seen do. The knock frequency is based on bore size, so this does make a difference. I switched from 305 to 350, and it does work (I get knock on the scanner before I hear it, and I don't get any on high test fuel, appears to work). I would recommend getting one for a 350, as a new one is good anyway.
L98GTA87
Oct 19, 2015 10:43 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
Ian Irvine
Sep 4, 2015 08:08 AM
