Hhheeeellllpppp!!!!!!!!!!!
Old Mar 22, 2002 | 01:16 PM
german's Avatar
Car: 91`GTA
Engine: 305cui
Transmission: Borg Warner T5
Hi,
today I installed in my 91`GTA 305cui,5G a chip from fastchip. When I now start the engine the fan starts and the service engine light stays on! And the engine doesnt run fine. Must I reset the ecm or anything??? PLEASE HELP!!!! My ECM has the no. 01227730.
Thanks,
Andy
Old Mar 22, 2002 | 01:51 PM
HighHopes85's Avatar
It sounds like the PROM might not have been installed with all the pins making contact. If it is a piggyback style, make sure everything is settled on the pins correctly. Make sure the clips that hold the MEMCAL in place are either holding the MEMCAL or the piggy-back board securely to the row of pins on the ECM. When I first got into this I would have a bad solder joint every once in a while and by applying slight pressure on the chip, the fans went off. Good luck, -Matt-
Old Mar 23, 2002 | 02:16 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
If the above does not work, then contact Fastchips...your EPROM may be wrong and there is nothing we can do, only them.
