knock sensor question on a 165 to 730 swap
Subscribe
Apr 13, 2002 | 07:56 PM
I am converting to a 730 and know the knock sensor is different for the 90-91 cars. I've read that the ohms are what makes up the difference? If this is so, can I just run a direct wire from the 165 knock sensor and put a resistor inline to cut the ohms back? Thus making the 730 a happy camper?
Reply 0
Apr 13, 2002 | 09:23 PM
Wes, you can. Measure the resistance of each knock sensor and put the proper resistance in parallel or series to make the sensor appear to be correct to the ECM
J
Reply 0
Apr 13, 2002 | 10:00 PM
Thank you. Just wanted to make sure. I plan to make a quick disconnest deal that will allow me to go back to the 165 knock setup without doing anything but switching wires. Wish me luck.
Reply 0
Subscribe
