Fan Switch pics?
Old May 6, 2002 | 10:06 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Fan Switch pics?
What does the fan switch look like? My fans don't work and I want to replace the temperature switch thing but can't find it. I've done a searcha and learned that its between #6 and #8 cyl., but I can't find it. Any help is appreciated. Thank you.
Old May 6, 2002 | 10:17 PM
NEEDforSPEED's Avatar
Fan Switch pics?
this happind to me to and im still working on it. fans don't work-that happind just test them you can take the dark green w/ white strip wire and jumper it to a ground. That should turn the fans on.
"i tryed to help you same thing happind to me and still trying to fix it"
Old May 6, 2002 | 10:20 PM
Car: 1989 IROC-Z
Engine: 383 stroker
Where is this? I don't have time to go run out and look for it right now. Does it run to the fan motor? Thanks.
Old May 7, 2002 | 09:38 PM
Car: 1989 IROC-Z
Engine: 383 stroker
To the top
Old May 8, 2002 | 01:33 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If you're aware of where the Temp gauge sensor is *between 1 & 3), the Fan Switch is in the same spot (except since it's the other side of the motor, it's 6 & 8) as if it were a gauge sensor, just the opposite side. (not too sure that makes sence but, it's late)
One way to test (w/o hunting) if the primary fan (ECM controlled, TPI, dual fans) relay is working is to do a code check (this kicks the main gan on), or turn on your A/C, car running or not for both, the fan should kick on. (guess that was 2 ways huh ?).
The fan switch (TPI) in the pass side head kicks on (grounds really) at a chilly 238° (about 20° after the primary), replacing it wouldn't get you much gain for cooling problems.
Thw subject of cooling fans needs to be a sticky...
Old Jul 8, 2002 | 09:24 PM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
Originally posted by deadbird
"at a chilly 238°"
Truely made me laugh !!!
Metallicamaro, here is a picture of the switch.
http://www.jegs.com/photos/5334026.gif
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
TA8487
Aug 16, 2015 12:21 PM
