Light Relay
Old Sep 11, 2000 | 12:35 PM
F_Bird89's Avatar
Light Relay
I have a 1989 Firebird v6. When my headlights are on, the right turn signal light remains off. When I put the right turn signal on, the light flashes. I also have the right turn arrow indicator on my dash board remain on (doesn't flash) when my headlights are on. I figure there is a short somewhere, but I can't figure out where. I had the 3 prong wire connector behind my right headlight replaced because when my brights were on, the right headlight stayed off. It works now. Any suggestions on where to look for a short or what could be causing this. Thanks.
Kevin
Old Sep 14, 2000 | 01:51 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
It may be a loose ground wire. Check the ground from those lights at the chassis.
Tim
BRoss99
Aug 10, 2025 05:08 PM
GTAman
Mar 15, 2019 11:40 AM
Papaginos
Sep 27, 2015 03:29 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
Omega
Aug 10, 2015 12:46 PM
