Oil pressure gage
Old Sep 23, 2000 | 03:23 PM
ramrod85's Avatar
Car: 85 Z28
Engine: 350/ 290hp EZ-EFI
Axle/Gears: 3.08 posi
Oil pressure gage
Guys, my oil pressure gage stays pegged with the ignition on. Replaced sending unit, but no help. Am I looking for an open or a ground?
85 Z28 LG4 with 220,000
Old Sep 23, 2000 | 07:18 PM
B L A D E's Avatar
Make sure you have the RIGHT sender... There are two types...one for a dummy light equipped instrument cluster, and one for the four gauge instrument cluster.
Old Sep 24, 2000 | 12:18 AM
ramrod85's Avatar
Car: 85 Z28
Pretty sure I got the right one. They had two different ones for gages, a 60 and an 80 psi. Mine is the 60.
Old Sep 24, 2000 | 04:33 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If your gauge is pegged, reading maximum pressure, then there is an open circuit, somewhere. If the gauge does not peg to maximum psi with the ign on & the engine not running, then you have the low pressure light type sending unit installed. Try shorting the tan wire that plugs into the sender to ground, with the ign on. The gauge should read 0 psi, if the wire is connected all the way back to the gauge.
Tim
Old Sep 25, 2000 | 09:54 AM
fastgta's Avatar
Car: 1984 Z28
Engine: 305 LG4
My 88GTA used to do the same thing and I couldn't find the problem. I took it to the dealer and all they did was run a wire from the sending unit and spliced it right into the wiring harness on the firewall! I was not happy, it looked bad! I tried tracing the harness out but couldn't figure out where the wire was going !
Old Sep 26, 2000 | 10:11 PM
ramrod85's Avatar
Car: 85 Z28
Well guys, it was a crack in the laminate circuit board on the back of the instrument cluster. What a pain, at least now it's done. Thanks for the help.
85 Z28 LG4 with 224,000
Prodigious
Oct 4, 2015 11:20 PM
angel2794
Sep 8, 2015 06:22 PM
solocus
Sep 2, 2015 12:14 PM
355sbcTPI
Aug 19, 2015 04:38 PM
