Power Door Lock Problems
My door locks on my 89 Firebird keep locking even when they're already locked when the engine is on or off. The unlock/lock switch only works some of the time. But regardless, the locking mechanism keeps sounding (about every 30 seconds). I'm not very familiar with how they work. Do I have to worry about my battery being used up or is it a minor enough feature that I won't need to. Any suggestions on how to fix it? Thanks.
Kevin
Kevin
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If the lock / unlock push button switches in the door are exposed to water, their contacts may get coroded & a conduction path forms due to the voltage potential across the switch contacts. Remove the switches (they are plug in), one at a time & see if that fixes the problem. If so, replace the switch(s), or pull them apart & clean them with switch contact cleaner. The two lock relays are under the kick panel, on the driver's side.
Tim
Tim
1992 Trans Am
May 10, 2023 07:19 PM
