Power Door Locks????
Old Oct 10, 2000 | 09:11 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
My driver side door lock sticks and won't lock the door, it almost closes and locks but it gets stuck. The passenger side works, its just the driver side. Any ideas?? Thanks!!
Looking for:
87 IROC-Z L98
84 TRANS AM H.O.
Old Oct 10, 2000 | 09:39 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
This is a common problem. You will need to pull the door panel & lube the lock mechanism near the door latch - spray lube works good.
Tim
Old Oct 10, 2000 | 10:00 PM
Administrator
I would have done that already, but I can't get the armrest off!! How do u get them off anyway??
Looking for:
87 IROC-Z L98
84 TRANS AM H.O.
Old Oct 11, 2000 | 07:48 AM
There are three torx head screws that hold the arm rest to the door. One up at the top - easy to see - and two under the arm rest, that go in to the door at an angle. Use a flash light to inspect the screw head - I've seen some metric hex head screws at the bottom locations, as well.
Tim
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
