power windows screwey.
Old Oct 23, 2000 | 12:31 AM
82taGODD's Avatar
on my 82 TA i have power windows. the drivers side works fine and the switches BOTH work normal. but the passenger side will not go down after a certain point. it will go all the way up, but after like 5 inches or so down, it stops. when all the way up, if i hold the switch it makes a loud repeated popping sound, and when its as far down as it will go, if i hold the switch down it makes a repeated poppping sound also just not as loud. the drivers side is fine, its just the passengers side. what can i do??
Old Oct 23, 2000 | 12:56 PM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
you can remove the passenger panel, clean the tracks for the window and relube them. look into the history here and on interiors for window advice on ways to do this if you're not familar with how.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
