Anyone have a clue???
Old May 25, 2002 | 09:05 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
I am still putting tuned port on my car which i took off of an 89 IROC. Anyways the vats thing is killing me so i bought a vats eliminator harness from painless..... Problem solved.. heck no....... Directions from painless says to plug the one wire into the f or f10 terminal....i look on the ECM and all i see is A,B,C, or D. Anyone ever hook one of these things up before?.... Does the elininator hook up to the ECM or am i missing something ??.... Everything is done except this... 2 months and counting... Anyone have an idea??
Old May 26, 2002 | 11:50 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
How many wires does the eliminator have? If it is a three wire unit, 12V, ground and a third wire then it will most likely go to the ECM. I am using aftermarket manuals but my one book shows the signal going to terminal B6 on the ECM. It should be a 50Hz square wave signal. If you need more help try to post the wiring diagram from the unit and I'll try to walk you through it.
RedLeader289
May 28, 2019 01:47 PM
92camaro350cci
Oct 14, 2015 09:29 AM
Jlanz55
Sep 9, 2015 09:09 AM
TheExaminer
Sep 6, 2015 11:40 PM
CORV3TT3
Aug 23, 2015 11:26 AM
