Need hatch advice!!!!!!!!!!!!!!!!!!!
Old Nov 2, 2000 | 04:37 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
OK, I have the electric hatch, all I did was open my hatch to get something out of it and when I went to close it, it wouldn't lock. I took a closer look and I saw that when it went down it didn't come back up to pull it closed. So I took the panel off and looked at it and I pulled it with my hands and it came up again, so I tested it and it was working, but my hatch release button isn't working?? So I put the panel back on and tested it with the key and it opened, I go to close it and it wouldn't pull it just like before. So it doesn't work and I had to unscrew the hatch support and thats how it is, and my hatch release button, which it always worked, doesn't. I need some ideas here!! What should I do?? Thanks!!
Looking For:
87 IROC-Z 350 TPI
84 TRANS AM 305 H.O.
[This message has been edited by IROCZTWENTYGR8 (edited November 02, 2000).]
Old Nov 2, 2000 | 09:04 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
I had this problem a few years ago. You need to chek all the switches in the mechanism. There should be atleast two from what I recall. Each one reverses the direction of the motor. Also check the relay for moisture damage. Incidentally, the relay is identical to the fuel pump relay. Good Luck
William
jrdturbo
Mar 31, 2016 02:58 PM
jaridjohn
Oct 5, 2015 07:01 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
formula00ra
Sep 28, 2015 11:50 AM
