Need Vss Help (speed Sensor)
Old May 30, 2002 | 11:56 AM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
I heard somewhere that the vss controls the torque converter lock up, the primary cooling fan and a few other things. my question is, after I swapped tbi to tpi on my 92 rs i Hooked the vss back up and nothing happens I understand that it is 2000ppm as opposed to the right one that has 4000ppm but if I have it hooked up shouldnt it read half my speed? Shouldnt it do something>?? the needle hasnt moved in once. I dont get any ses light either. Could this be related to the fact that when i swapped it i put in the harness for an auto when i have a manuel so i do not have the four prong connecter hooked up for the torque converter?? DO i need to put a jumper in there somewhere or what??
Old May 30, 2002 | 01:22 PM
long&low's Avatar
Car: 88 ext.longbed 1/2 ton
Engine: TPI 350
Transmission: Slushbox 400
Where did you run the VSS wires to?
On the TBI the signal first runs thru a VSS buffer and then out to the ecm,speedo, and cruise.
On the TPI it has to go thru the ecm first and then to the speedo and cruise
Old May 30, 2002 | 03:27 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
I just plugged it in. I took the whole tbi harness off but never saw a vss buffer. the tpi harness i have on there is for an auto and the tcc plug is not hooked up. where is the buffer??
Eric2ndGen
Nov 5, 2015 01:51 PM
angel2794
Sep 8, 2015 06:22 PM
fonzie85
Aug 13, 2015 11:50 AM
mizz0313
Aug 12, 2015 06:45 AM
