MSD Tach Adapter need ground wire off of coil???
Old Jun 3, 2002 | 08:26 AM
JDIroc's Avatar
I don't know which is the negative side of the coil, i don't have HEI the coil is seperate but its the stock coil and there are pink and white wires coming out of it, were can i splice in to it to get a ground for my MSD Tach Adapter to work
Old Jun 3, 2002 | 09:24 AM
IROC57TPI's Avatar
its the white wire closest to the front of the engine bay. My car didn't need a tach adapter when I put in my MSD 6A..
Old Jun 3, 2002 | 11:24 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
The tach adapter instructions should have that on them. In case you don't have them here they are.
http://www.msdignition.com/pdf/8910_tach_adapter.pdf
Old Jun 4, 2002 | 07:58 AM
JDIroc's Avatar
There are two which one
Old Jun 4, 2002 | 08:42 PM
Ozzy88GTA's Avatar
Engine: 5.0 TPI
You'll have to use the first diagram. The adapter wires came with connector for connecting to the end of the wires that are wrapped in electrical tape. Those are the white and red wires. In my install I had to splice into the wires about 12 inches from the MSD box due to the mounting locations. Just match the wires, white to white and red to red. The red is for the ignition and the white is for the pick-up. The wires that go to the coil are inside the hose-like insulation.
Old Jun 5, 2002 | 08:16 AM
JDIroc's Avatar
I don't have an MSD BOX my tach started going haywire when i would put the pedal to the floor, so the guy at the speed shop said it would solve the problem, I have it hooked up all except for the neg. side of the coil, thats the wire i am looking for.
Glowsock
Jul 24, 2025 03:15 PM
eightsixseven
Dec 16, 2024 01:50 PM
midias
Aug 15, 2015 05:07 PM
stalkier
Aug 7, 2015 04:49 AM
