I think I fried my computer!!!!
Old Nov 17, 2000 | 05:57 PM
BenDoe's Avatar
Hey guys, last night i hooked up a stray wire, to a stray sensor(i thought they went together) and it ran fine while I did it. Now it doesn't start, or even fire on any cylinders. I unpluged the sensor. I went to run a diagnostic test, and the computer doesn't do anything(turn on fan, or blink trouble codes). I checked the fuse, and thats ok. My question is, what else could it be, and if I did blow the computer, my friend has a computer from an 85 GM and was wondering if that would work in my car. I have a 1991 z28 TPI. Thanks
1991 Z28 305 1LE, TES headers, 3 Chamber flowmaster, Hi-reving cam... the usual street racer
Old Nov 17, 2000 | 09:02 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Nope, his computer isn't even close. Hooking stray wires together? Not a good idea. If you don't even get a check engine light with key on, engine off, and you do have power and ground to the ECM, than you need to get one.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
Old Nov 18, 2000 | 08:53 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
What sensor did you connect the wire to? Where does the wire come from & what color is it?
Tim
Old Nov 18, 2000 | 11:38 AM
BenDoe's Avatar
It was a single red whire that ended just over my passenger side wheel well. The sensor whent into a water passage on the passanger side cylinder head. They where the only two things on that side, so i thought i would connect them.. O ya one more thing, the wire melted and grounded out against my header... that could of done somthing. Does anybody know if a computer from an 85 GM will work?
Old Nov 19, 2000 | 07:46 AM
The red wire with a covered female stake on type connector is the fuel pump test connector. The sensor, on the passenger side cylinder head, between cyls 6 & 8, is the secondary fan switch - since you have a 1LE, A/C in not installed, and probably only a single electric cooling fan is used, in which case the sensor should not be connected to anything.
If the wire insulation melted & the red wire was grounded, you probably blew the 20 ampere in line ECM / fuel pump fuse, near the battery, under the hood - you probably checked only the 10 ampere ECM fuse in the fuse panel, under the dash, correct?
If the ECM is toasted, an '85 ECM will not work. You would need an ECM from a '90 - '92 VIN 8 (TPI 350), VIN F (TPI 305), or VIN T (PFI 3.1L V6).......or purchase a new ECM.
Tim
Old Dec 2, 2000 | 09:48 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Add to Tim's post of other GM cars that came with the 1227730 ECM:
1) 88-94 3.1 V6 PFI "T" LH0 in ALL GM cars except W-Bodies
2) 87-89 2.8 V6 PFT "W" LB6 in ALL GM cars except W-Bodies
And of course all TPI 5.0 and 5.7 1990-1992 F-body cars.
You can confirm the engine VIN Code by looking at the 8th digit and the Body VIN code by looking at the 4th digit.
2.8 and 3.1 V6 in late 80s - early 90s FWD GM cars are a dime a dozen in the wrecking yards. Just make sure you switch the PROM, as that is the difference from car to car.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
