My speedo, tac, work, but the gas, battry, oil ect do not work... what could be causing this, fuses? if so how do I tell if the fuses are bad?
Yeah its probally a fuse. Under your lower left dash panel above the drivers feet you will see a small part of the panel marked FUSES. Pull that panel down. Under it you will see your fuse bloke, swing that down. Your fuse block should be marked. If not your car manual and a chiltons will tell you which fuse is which. IF you can't find any of those pull each fuse and check. Anyways find the fuse marked guages. It should be a red one with a 10 amp rating. Pull it out it is transparent. Look at the metal bar going through the inside of the plastic. If it has a break in it replace the fuse. (Usually this is very obvious and it will have melted pastic or burn marks)
