headlights
Old Dec 6, 2000 | 04:26 PM
85trans's Avatar
headlights
Help! I recently purchased an 85 T/A. I have
only one problem left on the car and that is,
my headlights. They will go down but not up again. Does anyone know why this is?
Jeff
Old Dec 11, 2000 | 08:36 AM
johns84bird's Avatar
Car: Pontiac Grand Prix GTP
Engine: 3.8L V6 SuperCharged
You are going to have to check all of the wiring in the circuit with a multimeter, figure out if there are any problems. If not, it may be one or more of the three relays for the headlights. There is one isolation relay and two actuator relays and they all look they same on the outside. If it still doesn't work its most likely one or both of the motors that are bad. Replace as a last resort. Try finding ones in a junkyard and taking the internals out of them to replace yours. it is usually just the contacts and brushes inside that wear. Good luck.
John
84 Firebird with Trans am ground effects- 350 4bbl GM crate motor (LM1), T-Tops, automatic, K&N filter, 180* thermostat, ram-air hood scoop, flowmaster muffler, Accel cap & rotor, MSD Super Conductor Wires. Coming soon: new interior (grey), rear end work, subframe connectors, polyurethane bushings
Old Dec 11, 2000 | 04:28 PM
87 Firebird's Avatar
Also, you should check the signal bulbs in the front of your car. I had one bad bulb connection that kept one light from working.
Old Dec 13, 2000 | 12:38 PM
85trans's Avatar
I found the problem I replaced the relay that is directly by the battery box and they started working.
Thanks for everyones help.
Jeff
Jeff
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
