FogLights
Old Dec 13, 2000 | 09:40 PM
91FastBird60kmiles's Avatar
FogLights
Hey guys i have a 91 FireBird w/ the factory lower mounted FogLights.
My driver side light doesnt work???
I changed the bulb and made sure i didnt touch it, checked the fuse too.
Everything seems fine, and its only the drivers side, i checked it out the other day and everything seems to be fine....
Any suggestions?
Old Dec 14, 2000 | 01:38 PM
Stuart Moss's Avatar
Since you said that the drivers side fan did not come on, I presume that the passangers side did. Since one light works, then you can assume the wiring (including fuse) is okay. The only questionable portion of the circuit would be from where that light is connected to the other side.
If you don't have a voltmeter to check for voltage at the socket, I would suggest that you wiggle the wires at the base of the bulb while it is on and see if it comes on. If so, then it'll be a poor connection.
Inspect the base and be sure that the connection is clean.
Yellow Camaro
Dec 1, 2001 04:01 PM
Monkie
Oct 19, 2001 11:30 AM
TZFBird
Sep 5, 2001 06:09 PM
Doogie92Z28
Jun 26, 2001 09:14 PM
George Khawahie
Jul 28, 2000 09:52 AM
