I need quick help
Old Dec 13, 2000 | 05:17 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I need quick help
Ok after school today i go to start my car wont start.. so i thoght maybe my VATS went off waited 10 mins still wont start... Battery volts looked good i dono whats up the startes isnt crankning or anything it issent even makeing any noise at all what could be wrong???? i bought a new starter justincase it is that but im not sure it is
Old Dec 14, 2000 | 02:20 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
First of all, are you sure the battery isn't dead? And are you getting power to the starter? If the starter solenoid is bad it will make a click sound when you turn the key. You oughta try getting a screwdriver and jumping the two terminals on the starter. Other problems could be the park neutral safety switch (that's assuming you have an automatic), the ignition switch, and a relay for the pass code chip in the key. There's also a fusible link coming off the starter.
Old Dec 14, 2000 | 02:29 PM
Chris Luongo's Avatar
Since you just bought a new starter, there's a good chance that a connection there has come loose. Or the new starter or solenoid has gone bad. Sometimes, banging on the starter solenoid with a tire iron will get it to temporarily work again.
Even if your battery is fully charged, a jump start can never hurt to try.
Old Dec 14, 2000 | 02:49 PM
FAST RS's Avatar
Well i ahd the tow truck take me to my car to tow it back to my house well i get there started up perfectly fine no problems at all.. i dono what it was and so far no problems today either
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
