Why does my electrical guage pulse with the blinkers?
Old Nov 29, 2000 | 07:30 PM
Stell1579's Avatar
what is the cause or causes?
-Stell
1988 IROC 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans , K & N, 160 Thermostat+ Temp Switch, Relocated MAT, Cold Air
Old Nov 30, 2000 | 02:18 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
A small voltmeter needle deflection to a slightly lower reading when a turn signal flashes on is normal.
Tim
Old Dec 22, 2000 | 11:09 AM
jlc's Avatar
jlc
I had the same problem with old Lincoln Mark 4. A taillight was bad. Because the taillight has the running, turning, and the brake lights in the same bulb and each circuit uses the same ground, the bulb had short in it. The voltage would bleed over into the other circuits. I believe you have a bad light bulb. I changed the taillight for 75 cents and the problem went away.
jlc
-Stell
sheachopper
Jul 31, 2019 11:27 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
