need help quick!!
Old Jun 7, 2002 | 10:57 AM
maroon91rs's Avatar
Car: 91 Camaro RS
Engine: L03 305 baby!!!
Transmission: stock 700r4
need help quick!!
ok im trying to advance my timing,but my timing tab is rusted over and i dont know where any of the numbers are.is there anyone that can help me?
Old Jun 19, 2002 | 03:35 PM
esmartuek's Avatar
Car: 87 Camaro LT
Engine: 305 4BBL
Transmission: TH700R4
yeah, you have a bunch of peaks and valleys in the plate... the really wide valley is btdc 0. going towards the drivers side is going retarded while towards the passenger's side is advancing. the peaks are in increments of 4.
I have my timing set to 3 degrees btdc (advanced)... that is, it's just near the peak to the passenger's side.
hope this helps.
btw, you'll know if it's retarding or not... it starts to backfire and generally hate you.... meanwhile you have to advance it alot to know that it doesn't like it (pinging noises happen when accelerating)
-ET
Old Jun 19, 2002 | 08:44 PM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Hit it with some WD-40. Use a toothbrush to clean off the rust. Use some gas or alcohol to remove the WD and then use a piece of chalk and fill the stamped indicators. Gently use an acid brush to dust off the residue and you will have a great indicator under a timing light.
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
