Why should i ditch the Computer
I noticed a lot of people have ditched their computer controlled carbs and ignition. What are the advantages and disadvantages to this? And when you switch the ignition, do u just put in a non-computer controlled distributor and start her up?
--Steve S-- 84 Trans Am 305 HO 5 speed, completely stock emissions restricted slow 150 hp(chilton rating) 240 torquer that needs RELEASE!!!!
P.S. Daily Driver
P.S. Daily Driver
Car: 4
Engine: 6
Transmission: 5
Basically that's all you have to do: change the computer and distributor to the non-computerized one. Except if you have an automatic, then you lose the TC clutch unless you add a switch to engage it.
The reason I did it was because there was no way in hell to get the OE carb to work right on my 400 with (at the time) a Comp 282 solid cam in it. It ran great at WOT, that was easy, that's what you see posted about secondary rods and hangers, getting that part to behave is a no-brainer; but every other possible condition, especially cold start-up and drive-off, was a failure. I finally got sick of constant driveability problems and poor gas mileage. I put a Performance Distributors DUI and a Holley 6211 on it, and ended the problems once and for all.
rs_z28_vert
Sep 30, 2015 09:47 PM
Damon
Sep 26, 2015 04:29 PM
