Digital-Analog
Old Feb 3, 2001 | 10:27 PM
tiogarider's Avatar
Digital-Analog
Will a digital dash work if you swap it with the analog dash
Old Feb 4, 2001 | 08:26 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yes and no. Yes, because the sensors are the same 0-90 Ohms sensors that the "analog" guages use. No, becuase the connectors that go to the "analog" dash won't fit the Digital dash. You will need to find the digital dash connectors and replace your analog connectors. Also, if you have the "Drivers Information Center" with the dash, you will have a 3rd connector with alot more wiring (providing you want that to work)
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
