Fuel Pump Fuse
Old Jan 27, 2001 | 12:06 PM
86birdofdeath's Avatar
Fuel Pump Fuse
Do any of you know where the fuse is for the Fuel pump? I am hoping it is this and not the fuel pump it self. Thanks
Jason
Old Jan 27, 2001 | 02:50 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The fuse is either an in line fuse, near the battery, or the FP/INJ fuse in the fuse panel.
Tim
Old Feb 1, 2001 | 07:59 PM
Fast86TA's Avatar
anyone know of a way to test a fuel pump?
Old Feb 4, 2001 | 11:46 AM
There may be a fuel pump test connector on an orange wire near the fuel pump relay, or it may run to the ALDL connector as a red / black wire on terminal G. The other place to access the pump wires is just in front of the fuel tank, above the differential. There is a 3 prong connector mounted to the chassis, that the pump & sender plug into. The fuel pump wire color is tan or tan / white stripe.
Tim
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
