dome light removal caused short
Subscribe
Jun 24, 2002 | 12:14 AM
Today I went to remove my dome light to replace the headliner. I grabed some plyers to remove the circular clips. When the plyers touched the metal they sparked. Later I realized that I lost my stock stereo (only makes static sounds), power locks, center console compartment light, and dome light Radio fuse is good, but fuse labeled ctsy or something close to that is fried. Does anyone know what this fuse controls?
Would lossing axcess to the dome light by replacing the headliner be a bad idea?
How do you put the plastic dome light piece back on once the clips are removed?
Reply 0
Jun 24, 2002 | 10:36 AM
I dont have the good book in front of me. But I the the lighter outlet is hooked up it also.
Take out the dome light to replace headliner.
This clips should press back in.
Reply 0
Jun 24, 2002 | 10:56 PM
I also lost power to the button that opens the trunk. I already removed the dome light plastic pieces and droped the headliner, I was just wondering if the problem could be with the light fixture or wiring.
Reply 0
Aug 18, 2002 | 09:27 AM
dome light
Dude, I did the exact same thing! All you did was blow a fuse. Go under the dash, assuming you have your manual, and replace the fuse...Takes a 20amp. If ya need a pic of the fuse box and which fuse it is...PM me
Marie
Reply 0
Subscribe
