How do I get around the vss for a rear gear change?
I want to swap gears out in the rear end. I just replaced my vss which means my speedo is now working like brand new but I want steeper gears for the rear. I want to put in 3.23 gears with posi but I have the 2.73 gears. How do I get around the vss with out changing another form a 3.23 car?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You change the speedo gears in your trans to match your rear end. Check the FAQ.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Car: 04 GTO
Transmission: M12 T56
well, you can do it by changing the speedo gears (which yes, does work for e-speedos too), or you can buy a converter box that will automatically adjust the frequency of the VSS signal by whatever % change you need based on gears and tire diameter changes.
The first method is the cheapest, dirtiest, and least accurate. The second will allow you to set your speedo to be perfect no matter what you do your effective gearing from now on. And you don't have to take a bath pulling the tailshaft.
...ed
...ed
Car: Take
Engine: Your
Transmission: Pick
If you want to change your speedo gears, go here: Speedo gears
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
South East Thirdgen
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
Car: 1991 GTA
Engine: L98 350
Transmission: 4L60
Yeah I second that...Just what I was looking for!!! Thanx
Darrell
1991 GTA L98
K&N Filter, Subframe Connectors, 3.73 Gears, Hypertech Airfoil, Ported Plenum, Underdrive Pulleys, Flowmaster Catback, no cats, Hypertech AFPR, Fastchip.
Darrell
1991 GTA L98
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
