GM TPI Harness Install
Old Mar 23, 2001 | 07:15 PM
Chris Sartori's Avatar
Converting a 88 305 (E)TBI thirdgen to a 91 350 TPI. I have the complete GM factory harness off of the 91 TPI. Does anyone know if there is a difference between the two harnesses were it bolts into the firewall below the brake booster. Can I simply plug it in and go? Any help would be greatly appreciated. Thanks!!!!
Old Mar 24, 2001 | 07:13 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
I'll post a pict of a '92 (should be the same as a '91) and an '87 bulkhead connector pinout on Monday. You will need to either get a Helm shop manual for your '88, or use an ohm meter to check the pinout of the '88 connector. The '91 is different from the '88 in that it has three SIR (air bag sensor) connections, and two VSS connections (unless you have a digital dash).
Tim
[This message has been edited by Tim Burgess (edited March 24, 2001).]
Old Mar 25, 2001 | 09:09 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
The actually "engine" harness goes through the body behind the passenger fender. Once you get the harness under the dash, then you will have some wire moving to do.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Mar 27, 2001 | 10:25 AM
Here are the bulkhead pinouts for '84, '87, and '92:
'84:
http://albums.photopoint.com/j/View?...907&p=44947845
'87:
http://albums.photopoint.com/j/View?...907&p=44947837
'92, Sheet 1"
http://albums.photopoint.com/j/View?...907&p=44947828
'92 Sheet 2:
http://albums.photopoint.com/j/View?...907&p=44947822
<IMG SRC = "http://albums.photopoint.com/j/View?u=1554272&a=11793907&p=44947845">
<IMG SRC = "http://albums.photopoint.com/j/View?u=1554272&a=11793907&p=44947837">
<IMG SRC = "http://albums.photopoint.com/j/View?u=1554272&a=11793907&p=44947828">
<IMG SRC = "http://albums.photopoint.com/j/View?u=1554272&a=11793907&p=44947822">
Tim
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
