Wiring the Fans OFF?
Old Mar 28, 2001 | 07:06 AM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
How would I put a switch in line with the fans to shut them off when I start the car? Problem is with a DFI, it does not voltage compensate and when the car is hot and I try to restart, the fans come on, take away juice from the computer and no start. So how would I do this?
Steve
Old Mar 28, 2001 | 08:10 AM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
Sorry, forgot to mention the car is a 1991 Formula with the dual fans.
Old Mar 28, 2001 | 08:37 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
There are 3 relays mounted to the fire wall, in the engine compartment, on the driver's side. Two of the relays control the fans & the other relay controlls the fuel pump. The fan relays have a brown wire providing ignition power to the relay coils. If you put a switch in line with the brown wire, (one switch may be used to disable both fans simultaneously, since both relay coils use the same power source) when the switch is open, the fans will not operate, and when the switch is closed, the fans will function as usual. The primary fan relay has a dark green / white wire connected to the other side of its coil, that is controlled (grounded) by the ECM. The secondary fan relay has a gray wire connected to the other side of its coil, that is controlled (grounded) by the temperature switch in the passenger side cylinder head (closes above 238 F) and the A/C high pressure switch (closes above 232 psig), located in the liquid line.
Tim
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
krisner89
Oct 10, 2015 06:03 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
