door locks
Old Apr 3, 2001 | 04:36 PM
v6-3.1's Avatar
door locks
can someone tell me all the components in a power door lock?
also where do I wire the alarm to make the power door work(alarm is a excalibur)
Old Apr 4, 2001 | 01:54 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Look at the power door lock diagram at
http://www.geocities.com/vtcamaro/Wire-Diagrams.html
Connect the alarm + lock pulse outputs to the lt blue (lock) and black (unlock) wires going to the door lock relays. Check the current sourcing capability of the alarm system lock outputs - they are usually rated at around 300 ma. Check the current draw of your lock relays - the older third gen lock relays draw more that 300 ma & the newer ones draw less than 300 ma. If the relay coils draw more than the alarm system rating, use Bosch relays to control the lock relays - connect the alarm system lock outputs to the Bosch relay coils & use the Bosch relay contacts to switch the current to the lock relay coils.
Tim
Tim
Old Apr 4, 2001 | 08:26 AM
v6-3.1's Avatar
thank you for that link.
where is the power door lock relay located?
Old Apr 5, 2001 | 07:32 PM
v6-3.1's Avatar
please help!!
Old Apr 5, 2001 | 09:50 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Driver kick pannel
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
my86bird
Oct 23, 2015 12:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
SG91camaro
Sep 5, 2015 10:27 PM
