Map sensor connections (C,B,A)
Old Apr 7, 2001 | 02:05 AM
86 IROCZ28's Avatar
Can anyone tell me what the connections on the MAP sensor equal:
C = ?
B = ?
A = ?
C,B,A are all these but in which order???
MAP +5v ref
MAP GND
MAP Signal
Old Apr 7, 2001 | 10:13 PM
Vader's Avatar
'86,
MAP means you have a carbed engine, probably the 'H'.
The connections should be as follows:
C = +5VDC sensor reference (gray wire)
B = MAP modulated signal (light green wire)
A = Sensor ground - 0VDC (purple wire)
Hope that helps.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Old Apr 7, 2001 | 10:20 PM
86 IROCZ28's Avatar
Vader,
I have an TPI engine. Just needed to know these values because I am rewiring my ECM and going to Speed Density.
Old Apr 7, 2001 | 10:32 PM
Vader's Avatar
Gotcha.
I wondered how an IROC-Z ended up with a carbed engine.. :O
Later,
Vader
GTAman
Jul 3, 2024 07:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
Ironhead38
Sep 7, 2015 02:26 PM
Eric-86sc
Sep 7, 2015 02:10 PM
willyjoejr
Sep 3, 2015 09:26 AM
