Unknown Sensor please help
Old Apr 25, 2001 | 02:59 PM
88Roc350TPI's Avatar
Hi, On my 350 TPI there's a sensor that I'm not sure what it is. And it's not hooked up. Anyway, it's on the cylinder head on the passenger side of the car, and is between the #6 and #8 spark plug, same location basically as the temerature gauge sender unit on the opposite cylinder head. The plug on this sensor is the same shape as the one on the knock sensor down by the oil pan. There is nothing plugged into this so I can't trace where it goes or what it does. Please help. Thanks
Old Apr 25, 2001 | 03:33 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its the passenger side fan switch.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Apr 25, 2001 | 05:53 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
It's the fan switch! Controls when the fan kicks on and off! W/out that hooked up the fan won't kick on and off unless someone (you or a previous owner) has hooked up a fan switch elsewhere! The passenger side head is a b*tch to get to so I see that happen a lot! The guy/gal that owned my car before me welded a fan switch into a short metal pipe about the same diamater as the upper radiator hose and then cut the upper radiator hose and clamped this pipe between the two pieces!
If you decide to hook up your own fan switch, make sure you use a relay of some sort! I just bought an adjustable fan switch from Autozone for $20 and the adjustable device has a relay built into it already! Really simple to hook up also and it's very ideal if you want to go with a slightly cooler, 180 degree, thermostat!!
Old Apr 25, 2001 | 10:40 PM
JPrevost's Avatar
Car: 91 Red Sled
You could do that or just have the fan come on with ignition . That's the cheapest way to keep things cool but it's not really good for the fan motor to be always on when it doesn't need to be.
, Jon (350 TBI!)
91 Red My website
Old Apr 26, 2001 | 03:11 AM
<font face="Verdana, Arial" size="2">Originally posted by JPrevost:
</font>
I've already burnt up 2 fan motors....one stock from my '86 and the other from an '89 that replaced mine when it went out and I've never run my fan off ignition like that! I can just imagine the limited lifespan of a fan motor that runs constantly while the engine is on!! Do it right the first time and save yourself the PITA in the future! Just my opinion!
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
