85 Berlinetta digital dash problems
Old May 21, 2001 | 01:44 PM
Dan85berlinetta's Avatar
I just purchased a 85 berlinetta with a digital dash and the speedometer,odometer (LED type),and tach (vertical bar type) don't display at all (black),an have not for some time now according to the previous owner.The fuses are all good and have power to both sides using a test light.The wire is connected at the trans tail also.The other gauges (traditional type ,non LED style) seem to work Ok, and the dash lights and dimmer work.Local Chevy dealer says it is not a GM servicable part,and I should take it to a speedo or electronics shop.I'm reasonably well mechanically skilled and I would like to fix it myself if possible.I have read through the last 60 days of this post and have seen a lot of problems with digital dashs in general,but not my perticular one.Any help,insight,links,Ect... would be greatly appreciated.Thanks Dan
Old Apr 18, 2010 | 03:51 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
Re: 85 Berlinetta digital dash problems
you ever figure anything out with your gauges yet?
Old May 20, 2010 | 10:35 PM
DaveBerlinetta's Avatar
Car: 1985 Berlinetta
Engine: 5.0 LG4
Axle/Gears: 3.08 Peg Leg
My IP didn't work when I bought the car, also. All the vacuum fluorescent displays would not work, but the analog gauges did. It was the power supply board in the IP cluster. It's one of three circuit cards that make up the cluster. I didn't work on it at the time (about 8 years ago), I found a replacement and put the old one on the shelf for a later project. Yeah, it's still there.
To get it fixed, you need to find someone that's good with switching-type power supplies. Even then, it'll be difficult because that board was supplied as an off-the-shelf item to Delco, and I haven't come across anyone with schematics for that board. If anyone has 'em, please let me know!
Old May 21, 2010 | 04:23 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
u kno which board is the power supply? and i ve been lookin for schematics as well.
Old May 21, 2010 | 04:33 PM
Engine: 5.0 LG4
The last board.
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Sanjay
Aug 12, 2015 03:41 PM
beachrodder
Aug 7, 2015 04:27 PM
