Help w/Fuses
Old Jun 5, 2001 | 04:34 PM
smythe87GTA's Avatar
Help w/Fuses
87 GTA 305TPI: My dome light, map light (overhead console) power mirrors & glove box light will not work. Also, when I turn the car off, the radio erases all my stations. This just started happening, so I assume it's a fuse. Any suggestions as to which fuses those are would be greatly appreciated.
Old Jun 5, 2001 | 04:54 PM
Stuart Moss's Avatar
I'd suspect the Accessory fuse. It powers the items you mentioned with continuous +12 from the battery. If the memory for your radio is connected to this circuit, that would explain why it will not hold the stations programmed into it when it's turned "off".
In the future, if you suspect any fuse as being, just check each and every fuse for one that is bad.
jj74sd455
Mar 2, 2010 05:12 PM
HDon22s
Jan 23, 2009 06:56 PM
micali
Jan 12, 2009 07:17 PM
