Another Speedo Question
Old Jun 10, 2001 | 06:22 PM
MidnightZ's Avatar
The speedometer and odometer in my car stopped working. I thought that maybe my cable was broken, so I purchased a new one. When I removed my guage cluster, I turned the end of the speedometer cable, and it moved the speedometer. So, it isn't broken. I have cruise control on my car, so I was wondering maybe that is no good. I was planning on removing the cruise control anyway, but does anyone have any ideas of the problem or what needs to be replaced?
83 Z28, 305(LG4), T-tops, T-5 Transmission, Centerforce Dual-Friction Clutch, Hedman Shorty Headers, Weiand Stealth, 650 Double Pumper
Future Mods: Cam (undecided), Hooker cat-back
Old Jun 10, 2001 | 06:37 PM
Stuart Moss's Avatar
Do you mean that you turned the speedometer cable from the transmission end, making the speedometer needle move?
Did you remove the cable and check for damage?
Confirm that, with the cable fully inserted in its sheath connected to the transmission, that it does not rotate when twisted from the speedometer end, because it's being held stationary by the speedometer gear in the transmission.
Check the speedometer gear and ensure that the teeth are good (I think it's plastic).
[This message has been edited by Stuart Moss (edited June 10, 2001).]
Old Jun 10, 2001 | 07:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you have cruise control, you have 2 speedometer cables, one from the tranmission to the cruise control unit, and one from there to the speedo. Which one did you check?
Old Jun 10, 2001 | 07:38 PM
MidnightZ's Avatar
I checked the cable going from the cluster to the cruise control unit. I had it connected to the speedometer and turned the other end of the cable, and the speedometer did infact move.
Old Jun 10, 2001 | 07:53 PM
So have you determined if the speedometer cable is broken?
If you've confirmed it's good, then check the gear drive for the cable.
Old Jun 10, 2001 | 08:08 PM
MidnightZ's Avatar
Thanks guys...I'll check it out.
Eric2ndGen
Nov 5, 2015 01:51 PM
stickychinsac
Aug 31, 2015 06:06 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
redmaroz
Aug 16, 2015 11:40 PM
beachrodder
Aug 7, 2015 04:27 PM
