that annoying buzzer
Old Jun 19, 2001 | 07:38 PM
85 - LG4's Avatar
How can I disable the buzzer that comes on when I open the door with the kee in the ignition, but without keeping the domelight from coming on?
Old Jun 19, 2001 | 08:42 PM
POS Camaro's Avatar
Car: 1986 Camaro Z28
Axle/Gears: 3.73 Posi
There is a module in the convenience console (under the dash on the right hand side of the steering wheel) This module does all of the noises (lights on, seatbelt, key in ign., etc.). Remove this module, it is the biggest one. The others are choke heater relay and turn signal relay. The panel they mount to swings down.
1985 Camaro Sport Coupe
LG4, 3.08 rear, A4
Bone Stock
1999 Blazer
4x2, 4.3L, 3.42 rears
Decidedly slow
Old Jun 25, 2001 | 02:24 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
If you still want your other buzzers to work (headlights on, seatbelts, etc) then take out the buzzer unit and bend out the prong that controls just that circuit (I think it's the 3rd one in on the bottom). You can test for it by removing the buzzer and with a test light or multimeter check for positive voltage with the key in the ignition and the door open. There will only be 2 positive voltages, one is the buzzer for that circuit, the other is constant power. See which one switches off and you're home free.
'91 RS
SFC's & Poly bushings so far.
Old Jun 28, 2001 | 10:30 AM
85 - LG4's Avatar
all original except Kenwood KDC-X815 CD player
GTAman
Jul 3, 2024 07:29 PM
Street Lethal
Apr 30, 2019 12:14 PM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
Out-Cast
Aug 22, 2015 07:49 PM
Brett Gutshall
Aug 23, 2001 12:28 AM
