motors...single or dual fan, who's stronger?
Old Jul 8, 2001 | 03:51 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I looked up the GM part numbers and the single fan motor has a differant number then the dual fan motors. They look the same so what's the differance? Is on stronger (faster) then the other? If so which one?
Is there any way to get the factory specs on each?
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Jul 8, 2001 | 04:35 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Hey, thats funny, I looked up those numbers too!
The single fan had a different part number than the dual, but BOTH dual fans had the same number. I think since the duals have smaller blades to spin, they have a lower wattage rating than the single fan, since the single has a larger blade to spin. No sense in using a chainsaw to cut butter or a butter knife to cut a tree now is there? Thats just my theory though.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Jul 8, 2001 | 05:22 PM
Engine: 4.0L
Ah, I knew that GMtech. I thought someone had an answer for me when I seen the reply.
86 Camaro Sport
My Camaro Project
Old Jul 8, 2001 | 06:26 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Thats odd i thought they were slightly different. One of the motors went out on my dual fan setup. I had a motor from my 91 rs with the single fan. So I thought that I would see if it would work. I had a problem with the fan blade fitting the motors shaft or something. I did get it too work but it vibrates some. I cant remember exactly what was different though.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Jul 8, 2001 | 07:53 PM
Engine: 4.0L
Interesting, I will have to pull one of my dual's and compare the shaft to the single fan. from the outside they appear to be the same.
MikeH.
How does the single fan motor cool in the dual setup?
Old Jul 8, 2001 | 08:17 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
It seems to work fine I didnt notice any difference really. Ive never had a problem with the car overheating. The motors been on there probably 6 months.
I cant remember what it was about the fan blade fitting the shaft though. It went on the shaft but something was different. It made it slighlty out of balance.
Let me know what you find out I would like to know myself.
ZEEYAA
Apr 16, 2023 08:29 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Night rider327
Oct 9, 2015 09:25 AM
91 SrS
Oct 7, 2015 04:32 PM
