Brighter Bulbs for Taillights
Old Jul 8, 2001 | 05:02 PM
XxMoLexX's Avatar
I put a set of Blackouts on my camaro.. and i think the lights are a lil too dim during the day. Are there any kind of bulbs that wil fit stock specs but are brighter?.. I know i should just take them off during the day but then wat wood be the point of em
I drive around with the parkin lights on so that they will b as bright as possible... but i still wood like to know if there is anything better.
White 91 3.1 RS.
T-Tops
12" tube in the "trunk" (That hole they call a trunk anyways)
16" ROH Rims
Firestone Firehawks
BOSCH plugs and wires.
Energy Suspension Tranny mount and bushings
Old Jul 8, 2001 | 08:38 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Do a search...It seems like someone posted some brighter ones with part numbers.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Jul 9, 2001 | 08:22 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Use a 2057 instead of an 1157 (if you just have 1157's in there). They have a brighter 'brake' filament. There might be a halogen upgrade as well - I don't know (haven't looked into it).
An idea I did have, was to use just the blackout panel itself (remove the original taillight housing), and mount a boatload of LED's into them for the marker, brake and turn lights; but wasn't able to come up with a solution for the back-ups (mebbe a nice bright driving lamp or something). Still just an idea
Pete
Pete's Place
HiOutput Tech Page
83 SC
originally a V6...now
210+k mile LG4/5-speed
14.891@95.54
Old Jul 10, 2001 | 02:41 AM
Jza's Avatar
Jza
Your owner's manual calls for 2057 anyway, so I hope you're not using 1157. I use 2357.
Old Jul 12, 2001 | 12:03 AM
Chris Luongo's Avatar
I saw at AutoZone they have LED brake light bulbs with standard #1157 bases....but that doesn't mean they are brighter.
Fronzizzle
Feb 9, 2017 09:31 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
92firebirdchris
Exterior Parts Wanted
Oct 1, 2015 01:38 PM
pimprs
Sep 10, 2015 03:34 PM
