How to remove fuse block?
Old Jul 19, 2001 | 08:54 AM
BlackZee's Avatar
How is the fuse block removed? I think I have a wire broken on the backside of the block, causing a short. My main problem is the fuse controlling the taillights blows instantly after turning the headlights on. I found a broken wire on the headlight switch harness, one of the two that are paired. I soldered it and replaced the headlight switch and tested it before putting everything back. It worked fine until I was putting it in the dash, then the fuse blew again. This leads me to believe there is a broken wire between the switch and the fuse block. I hate electrical problems with a passion! Thanks for the help!
Old Jul 19, 2001 | 01:53 PM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
Take your kickpanel off, look up at the fuse box-there's tabs on either side that will allow you to flip it down. If you want it right down, there's two screws at the back.
Old Jul 19, 2001 | 02:24 PM
BlackZee's Avatar
Thank you!
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
anesthes
Mar 10, 2016 10:35 PM
gixxer92
Sep 1, 2015 04:32 PM
3rdgenparts
Aug 8, 2015 07:09 PM
