165 to 730 conversion: MAP sensors all same???
Old Jul 27, 2001 | 04:16 PM
Sarkee's Avatar
I'm looking to do a 165 to 730 conversion on my '86 L98, as per http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
I have the 730 ECU; the 16151348 Memcal is in the mail. I understand any knock sensor from a 730 donor vehicle will work (V8, V6, L4 all same), but must the MAP sensor be for a V8 or can it be from a V6 or L4 (as long as it's a '91)?
Does the '91 MAP sensor have to match the PROM? Say, be from/for a 350?
Thanks!
Old Jul 28, 2001 | 03:44 PM
leirch's Avatar
They should all be the same. But i'm not real sure. Go to a local autozone or advance auto. They should be able to answer every one of those questions.
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 SR Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
db057
Jan 10, 2020 08:55 PM
bbsr72
Apr 2, 2016 09:12 AM
Giocio
Oct 1, 2015 12:20 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
