help
Old Aug 24, 2002 | 04:20 AM
ChickenFried's Avatar
help
I just put a 355 with a carb in my 91 rs. I also swapped the t5 for a 700r4. The damn car won't start. the starter does nothing. I tried connecting the neutral swith that went to the transmission and I hold down the clutch to hit the switch behind the pedal but nothing happened. I checked for power in the purple and yellow neutral safety switch wires and the ones that went to the tranny have power but the ones behind the clutch do not. I have no clue what the problem is. Is there something that needs to be hooked up that I didn't use or what. Give me some ideas of what to try please.
Old Aug 24, 2002 | 06:47 PM
eddie938f's Avatar
there is a starter enable switch,fuseable links ign. switch switch.tryjumping the starter with a screwdriver&see if the car will start.
