installing msd 6a with gm blaster coil.. gap?
Old Aug 11, 2001 | 10:54 PM
JeffC1500TBI's Avatar
I will be install my 6a tomorrow and I'm wondering if I have to pull all my plugs and regap for this? they are currently stock at .035 gap.. from what I could understand in the book it says to set it to .050.. should I try it the way they are or change them??
thks
'88 C1500 350 TBI
Belltech 2/4 Drop,
Nitro Drop Shocks,
3.73 Rear gear ratio,
Edelbrock performer TBI intake, performer cam, timing chain,
Hiflow cat with Rhino dual 2 1/2" out the rear. American Racing Neptune 16x8 wheels with Kumho 712's, 255-50 series
Old Aug 12, 2001 | 01:00 AM
Jza's Avatar
Jza
I left mine at .035 after I installed an MSD 6AL and Blaster coil without any problems. Then when I changed my plugs I gapped them at .045. MSDTech just said .010 over your current gap, so that's what I went with.
Old Aug 12, 2001 | 04:50 PM
well... got it all installed.. made a nice bracket to go where the stock silencer for the breather was.. everything was just plug and play pretty much after that. routed all my wires. the nice thing was the battery is right there so I used the ground from the fender where that batt grnd is connected and the positive right to the battery... that's all fin and dandy haven't had much time to test out the higher end yet but seems to idle a lot nicer now... the only prob is I turned my 3500 audio system on and I have that lovely noise. I think I narrowed it down to being produced by my clarion eq650 whitch is a 4 volt preamp, eq, & cross-over. If I put barrel connectors between the connections from the head unit to the eq and the amp that runs my mids/highs I don't get the noise... I wonder if I put a noise filter on the eq/preamp if that will solve it?? anyone else ever had this prob??
I don't really believe in using noise filters because normally if everything is grounded and routed properly you shoulnd't get noise.. and I never had one bit of noise t'ill now..
'88 C1500 350 TBI
Belltech 2/4 Drop,
Nitro Drop Shocks,
Old Aug 12, 2001 | 04:51 PM
oh yeah one other thing.. I removed the plugs and gapped them all to .045.. stock was .035
RedLeader289
May 28, 2019 01:47 PM
stalkier
Dec 6, 2015 11:25 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
RedLeader289
Sep 23, 2015 06:50 AM
roysatikas
Sep 22, 2015 08:15 PM
