Installing an MSD 6AL
Old Aug 26, 2001 | 06:55 AM
NOCANDO's Avatar
I just got my MSD6AL and Blaster coil. I've seen other pictures where the MSD6AL were mounted far by the fender well. I have the MSD harness, but its short. Do I have to splice longer wires to the harness???
Old Aug 26, 2001 | 01:40 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If you want the wires to reach to where you want to put it, yes, you'll have to splice.
The mind is like a parachute, it only works when its open
Old Aug 26, 2001 | 01:56 PM
Jza's Avatar
Jza
I have mine mounted where the charcoal canister is, and I didn't have to shorten or lengthen a single wire. Everything hooked up right out of the box with the wiring harness.
Even if yours didn't reach, you don't have to hack up the wiring harness, just the wires coming from the box itself.
toronto formula
Nov 10, 2015 06:17 AM
LittleFranks
Sep 17, 2015 12:22 PM
theurge
Aug 21, 2015 12:46 PM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
