Power release solenoid?
Old Aug 23, 2001 | 02:08 AM
firebirdgirl_87's Avatar
Hello everyone. : )
I recently installed a power hatch release switch on my 87 firebird, I bought a relay sensor and installed it under the passenger side dash. I was hoping it would work by releasing my hatch but nothing happens. I have a power pull down motor that works fine but I think I'm missing something. I've heard of a power release solenoid but I'm not sure if it is all ready installed or if I need to find one and install it myself for the power hatch to work. If this is the case I was hoping someone might have a spare that they would be willing to donate for postage. Any help would be appreciated. Thanks
Red, 1987 Firebird
coupe, V-6, 2.8 totally
stock down to the
wheels.
Old Aug 26, 2001 | 03:18 PM
Z28fromItaly's Avatar
The power solenoid must be included in the motor assembly. Check it out, it could be just a missing connection
Old Aug 28, 2001 | 02:26 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Which power pull down hatch motor assy do you have? Attached are pic's of the solenoid equipped style and non-sloenoid style. The silver item is the release solenoid. If not you will need to either add it or swap assy's. Also I've discovered that on auto equipped cars the ground wire (black with a white stripe) ties into the neutral safety switch on the gear selector. On manual equipped cars it connects to the parking brake. In both cases it was to keep you from popping the hatch accidentally while moving.
Click on the link for the pic's of each version. BTW, I also make the replacement plastic guides in case you need them. Good luck, Lon.
http://photos.yahoo.com/bc/topdownso...h%2bpulldown%2 bassy%26.dnm=view%2bof%2bmounting%2bside%2bof%2bassy.jpg%26.src=ph
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
[This message has been edited by lonsal (edited August 28, 2001).]
Old Aug 28, 2001 | 05:00 PM
Thanks Guys I'll check it out!
injdinjn
Aug 28, 2015 12:51 PM
sailtexas186548
Aug 24, 2015 10:11 PM
neekolzun
Aug 24, 2015 04:59 PM
Accerrito22
Aug 23, 2015 07:22 PM
smooth
Aug 18, 2015 06:34 PM
