Need some help with coolant fans.
Old Sep 18, 2000 | 01:53 AM
Grinch-92Z's Avatar
I will be going to the track this weekend.
The car takes forever to cool off between passes.
I know I need a different stat and an adjustable fan relay. However I lack the cash to do that this week.
My question is: Does anyone know how to hook up a simple switch that I can turn the fans on manually with?
I need the fans on without the engine running while I am waiting to run again.
1992 L98 Z28
Dark red Metallic
Old Sep 18, 2000 | 08:04 AM
tesla042's Avatar
Yesterday, i was toying around with an idea like that.. I took my secondary fan OUT of the car, and hooked + and - straight from the battery to it.. it spun like a madman!
I don't see why you couldn't do this.. hook one terminal straight to +, the other terminal to a switch, then the switch to ground.
Probably just put the switch under the hood for easy wiring..
Hmm.. Any smart ppl: Anything wrong with this idea? Is there too much drain or anything?
Hmm.. BTW, this won't work with the engine off unless you have an electric water pump.
91 T/A 305
STB, Airfoil, Hooker cat-back, pseudo-cold air to K&N, Accel coil, !cat, !smog pump.
300 lb*ft of rice churning power.
Old Sep 18, 2000 | 05:02 PM
Grinch-92Z's Avatar
What if I leave the ignition switch on? Would i be able to run the fan with the engine off but with the key in the on position?
Old Sep 18, 2000 | 06:20 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
If your water pump isn't circulating water through the engine and radiator,then the fan is only cooling the water that's sitting in the radiator.Also,the fan will blow out all the hot underhood air. But this is only going to drop your temp a few degrees unless you have your coolant circulating through the engine.To do this without running the engine, you'll need an electric water pump.But I don't know how long these pumps will last on regular daily drivers, since the electric motor is constantly running.
Old Sep 19, 2000 | 04:14 AM
Kevin S's Avatar
Here is what I did.
You have a temp sensor that when the coolent reaches a specific degree it turns the fans on.It will have a one wire hook up.That wire is a ground for the fan relay.Get a toggle switch and some wire.16 gauge wire should do the trick.Splice into the ground wire of the sensor and hook it up to the switch.Then the other terminal on the switch will go to a ground.
When you want the fan to come on just throw the switch.But it will only work with the key on.
I can send you a diagram of this if you are interested.Email me.
Kevin S
10.9 @ 62.87 (1/8 mile)
89 RS 2.8(bored .030)
B&M shift Improver
B&M Mega Shifter
Perma Cool trans cooler
Accel Wires,
Ignition module,
Super coil
Streetrunner chip(for now)
Flowmaster
1.52 Roller rockers
Things You Will Never Hear a Man Say....
Damn, too bad this car isn't a four cylinder.
Old Sep 26, 2001 | 01:17 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
hey kevin, i am hookin something like that up for mine. the sensor is bad, i think. so th efan doesnt come on. i am gonna hookit up to a toggle. can u possibly send me teh pic. thatnks spartyon@hotmail.com
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
