I want to hook up my tach/HELP!
Old Sep 16, 2002 | 06:20 PM
Maximus's Avatar
Car: 1992 Camaro Z28
Transmission: 5spd.
One of the wires needs to be connected to the (+) pos. ignition wire. Where is this? I'm not that good w/ cars and could use some help. I just got the car about 3 months ago! If you have any pics, or detailed description would help alot! .....also I had the tach in my 4cyl car previous, and for that you had to clip the two wires behind the tach for a 4 cyl, and just leave it if it was a 8cyl. If I twist the wires back together would it work the same? I hope I don't have to buy another tach! Thanx again.....:hail:
Old Sep 16, 2002 | 06:52 PM
mudaholic's Avatar
the wire you want should be on the ignition coil.. as for the snipped wires, you should also be able to reconnect them and it should work for your 8-cyl
Old Sep 16, 2002 | 08:40 PM
Maximus's Avatar
Transmission: 5spd.
Is there more than one? Is there a colored wire I should look for?
When I installed it on my 4cyl. I just spliced it w/ the "yellow"
wire. That was on my honda, should it be the same on the chevy? Thanx again....
Z28/ZR1
Oct 23, 2015 01:04 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Derrick86
Oct 1, 2015 05:12 AM
Gordonr1973
Sep 29, 2015 11:59 AM
